Re: Magneto timing on H
Posted by JRSutton on July 09, 2012 at 10:05:19 from (75.130.109.233):
In Reply to: Re: Magneto timing on H posted by david G on July 09, 2012 at 07:09:52:
I'd say definitely keep it 2 degrees after tdc.
It's a safety issue in case you ever need to hand crank it.
In these old slow low compression engines, you won't notice any performance difference from a few degrees.
If you go TOO far past tdc, it'll be tougher to start - but 2 degrees isn't too far.
