Re: 460 starting problems
Posted by El Toro on July 09, 2012 at 11:22:58 from (108.3.148.85):
In Reply to: Re: 460 starting problems posted by reddog300 on July 09, 2012 at 10:31:48:
Use a volt meter and check the charging voltage across your battery terminals with the engine at 1/2 throttle or better. Should see 14.5 volts if you have a 12 volt battery. Your low voltage could be the reason for your engine not starting. Hal
Today's Featured Article - Dad's 1945 Farmall A - by Bobby Duke Jr.. I am writing about my Dad's 1945 Farmall A. The tractor was purchased in 1945 by his father, Mr. Davis Duke. It was used to farm tobacco from 1945 to 1963 by my grandfather and by my father. ... [Read Article]
