Re: Need info on International 444
Posted by Big Don on October 02, 2000 at 11:48:39 from (24.65.54.137):
In Reply to: Need info on International 444 posted by Bert on September 30, 2000 at 20:34:46:
Bert:
There is a lot of confusion about 444 tractors. There was a Louisville assembled 444 tractor that was sold in the US but there was also a British built 444 tractor sold in Britain and Canada from about 1972 to 1977. The US version had a Delco electrical system and a round front axle similar to an Int.504. The British version had a Lucas or Bosch electrical and a square front axle with a power assist steering cylinder on the left side of the tractor. If the serial number has a letter B in it then you have the British version while the letter U indicates US manufacture.The 2 versions of 444 share a common rear end and if Diesel the engine is the same otherwise they are quite different tractors.
Hope this helps. Don.
Post A Followup
: Re: Re: Need info on International 444
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
