Re: Y69 will not start.
Posted by Armand Tatro on July 09, 2012 at 19:19:56 from (98.227.26.140):
In Reply to: Y69 will not start. posted by grizzlyclaus on July 09, 2012 at 14:57:37:
What cylinder are are you calling # 1? Should be cylinder at fan end of engine which would be the front of the engine. Also could your disturter be 180 degrees off? Also the only sure (and safe) way to check compression is with a compression tester. Armand
