Re: 706 shifting
Posted by caterpillar guy on July 10, 2012 at 01:22:55 from (66.227.141.21):
In Reply to: 706 shifting posted by Al Barclay on July 08, 2012 at 13:40:15:
The biggest thing that goes bad is the hole in the lid that holds the reverse pivot. Hole gets worn then won't go into reverse good. We just changed the mechanism over to the 56 series solved the problem and is fairly easy. The 56/66 series has a separate link for the reverse fork. The reason they have the lower case H pattern.
