agree with others - but easy enough to check if you want to be sure - just remove the cap.
I'm pretty sure you'll find the problem doesn't go away.
Those carbs do flood easily - it's most likely your floats either aren't set right or leak, or the needle valve is junk. Could be junk in the valve keeping it from closing.
Either way - it shouldn't really be a big proglem if it doesn't leak while running.
Instead of turning the tractor off by the kill switch - shut the gas off at the valve and let it run itself dry.
It's a good idea to do it that way anyways, for several reasons. When you're ready to start it - turn the gas on and start right away before it starts dripping.
Not to say you shouldn't attempt to fix the problem - but that'll at least hold you over more safely until you do.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
