Posted by JRSutton on July 10, 2012 at 09:18:44 from (75.130.109.233):
In Reply to: Y69 will not start. posted by grizzlyclaus on July 09, 2012 at 14:57:37:
Many people get confused with TDC - remember there's a top at the exhaust stroke, and a top on the compression stroke.
So you want it to fire on the compression stroke (or immediately at the end of the compression stroke).
It's good to have it fire a degree or two after tdc - to avoid kick back, especially hand cranking. Once started, the mag goes into run mode and advances itself.
Go any further than about 5 degrees past tdc and it's going to get increasingly harder to start. You really want to be just very slightly after.
Also - just because you're getting a spark doesn't mean you're getting a good spark. If the arm in the mag is off a few degrees, you'll see a spark, it just won't be very strong. Hold a plug wire near ground - make sure it's at least 1/4" solid blue arc.
If all that checks out - try a little starting fluid. If it fires on that - you'll know you should probably focus more on the carb.
I'd also pull each plug and make sure that each one is sparking - never assume.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
