Re: Trailer for tractor
Posted by T_Bone on October 02, 2000 at 13:18:23 from (207.254.53.114):
In Reply to: Trailer for tractor posted by BTD on October 02, 2000 at 12:20:29:
Hi BTD, I always figure what I'm going to haul. Tractor weighs 5500lbs wet, trailer should weigh about 4000lbs so thats 9500lbs total. A class 3 coupler is not heavy enough for your gross weight. A 2-5/16" ball coupler would work but just barley as I think most are rated 10,000lbs. So 5th wheel hitch is what your looking at. Also take a look at the tires. If the tires were 235-16 range E then you could get 3000lbs maximum load per tire or 12,000lbs gross for a tandum axle trailer so just making weight with nothing to spare! Axles would be 7,000lb axle or 14,000lb for two axles. The axles should be stamped with load range. Anything less you can get by with but when will it break? I don't know do you? From this you should be able to tell what you need! T_Bone
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
