Re: Farmall B, water in oil, from around #1 cyl.
Posted by old on July 10, 2012 at 10:10:39 from (209.86.226.40):
In Reply to: Farmall B, water in oil, from around #1 cyl. posted by David Inman on July 10, 2012 at 06:50:46:
If stop leak isn't doing it then bite the bullet and pull the head and do all 4 sleeves and a new head gasket. Being a thermosyphien (sp) system they get hotter then a lot of engines so they expand a bit more so the sleeve seals will be more likely to leak and when they do most of the time you have to do it right or give up
