Re: Farmall M- 3 Mechanics Stumped
Posted by Janicholson on July 10, 2012 at 10:59:40 from (199.17.55.151):
In Reply to: Farmall M- 3 Mechanics Stumped posted by TiffanyM on July 10, 2012 at 09:29:12:
If when the tractor is sitting still and running at idle the operator pulls open the throttle very rapidly, it dies, I suspect carburation problems with the power curcuit. (main jet and passages, and the load richness control screw (bottom front of bowl. 4 to 4.5 turns out is about a good starting point from gently screwed in all the way, do not tighten it, it is a valve). If it runs up to speed easily the issue might be electrical.
Putting a test light on the supply to the coil (lit when the switch is in the run position should stay lit when trying to move the tractor. If it goes out when the tractor quits, it is supply voltage. If it stays lit and good brightness, the issue could be a short to ground in the distributor. Jim
