Re: Farmall B, water in oil, from around #1 cyl.
Posted by gene bender on July 10, 2012 at 11:00:05 from (67.55.226.123):
In Reply to: Farmall B, water in oil, from around #1 cyl. posted by David Inman on July 10, 2012 at 06:50:46:
Without a water pump your stop leak stuff probably just went to the bottom of the radiator. You will find when you remove the sleeves a lot of junk built up around the bottom in the block where the o-rings are. I would replace all of them. I also would remove the engine from the trctor so you can put it on a stand and then be able to clean up the inside of the block ive done many in the last 15yrs and the crud sometimes blocking coolant flow is always there. We seem to have a lot of bad water.
