Re: Farmall Super A.... electrical question
Posted by old on July 10, 2012 at 12:09:08 from (209.86.226.19):
In Reply to: Farmall Super A.... electrical question posted by Ron Larson on July 10, 2012 at 11:05:36:
Very simple trouble shooting should tell you what is wrong. Check your spark and make sure it is a good blue/white spark that jumps a 1/4 inch gap or more. If it does not do so then you may have the points set wrong gap should be 0.020. If you have good spark then pull the carb drain plug and let the gas flow for a few minutes and be sure to catch it for 2 reasons. #1 to check it for dirt/rust/water and #2 to be able to use it
