Re: Farmall M Starting Problem
Posted by cole in mo. on July 10, 2012 at 16:51:17 from (65.255.149.240):
In Reply to: Farmall M Starting Problem posted by Brady Miller on July 10, 2012 at 16:42:03:
The condenser wire is connected to the points, so if you have fire at that point, and the points are clean, and adjusted right, you should have fire when the break.
