There is no good way, you can put on the one for a distillate/kerosene engine, but it attaches to the fitting for the lower hose, and will always be cold. I fitted a modified upper Super C outlet (which has a water pump) on my Super A and mounted the gauge to a bolt on the governor so I could see it. It doesn't work right with thermosiphon, and generally reads high, temp drops rapidly at idle. Probably has to do with the non-uniform flow of the water due to thermosiphon. Usually runs on the lower side of the red, or about 212 degrees. If I put on a water pump, IMO it would be more accurate, but those engines usually don't run hot anyway so it really isn't needed.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
