Re: Farmall M stuck in reverse
Posted by Darryl 2 Ms on July 10, 2012 at 17:57:46 from (64.12.116.73):
In Reply to: Re: Farmall M stuck in reverse posted by uncle henry on July 09, 2012 at 17:21:27:
Thanks Uncle Henry. Someone already did a little welding on the shifter, and the slots in the rails need some attention when I finally do get the big cover off. I was thinking of jacking up the rear, get the wheels off the ground, and push in the clutch while I play with the long screwdriver. Already tried it in the field but no luck. Maybe with all the pressure off things will slide into place easier. Thanks again... Darryl
