Re: Farmall M Starting Problem
Posted by Bob M on July 10, 2012 at 18:08:49 from (65.110.154.2):
In Reply to: Re: Farmall M Starting Problem posted by Brady Miller on July 10, 2012 at 17:31:09:
Presuming you see no voltage where your finger is pointing, problem's a short in the distributor. Could be the insulating bushing supporting the distributor primary terminal, shorted points or (long shot...) a shorted condenser.
Suggest removing each part one at a time and repeating your voltage check after each one. When power shows up at the coil terminal you've found the shorted part!
