Re: 1066 Hydro, Hydro oil excessive usage?
Posted by wisbaker on July 10, 2012 at 21:25:18 from (207.118.174.54):
In Reply to: 1066 Hydro, Hydro oil excessive usage? posted by DAVID KNECHT on July 10, 2012 at 15:47:11:
The oil has got to be going somewhere- choices are leaking or burning. Can be leaking out or leaking into something else that holds fluid (radiator, crankcase or other lubrication oil) Or it can be leaking into the intake or some where else that eventually puts it in the fuel tank or cylinder, it gets burnt and exits the stack. If you're not seeing deposits or dribbles on the tractor there is the possibility it's leaking under enough pressure to spray away from the tractor.
