Re: F 12 fuel pressure question
Posted by rustred on July 11, 2012 at 09:04:21 from (184.151.222.55):
In Reply to: F 12 fuel pressure question posted by Craig45 on July 11, 2012 at 07:40:22:
appears to be the fuel pump. when cranking should have a full stream shoot out under pressure. also check the fuel pump push rod for travel. if you dont have the travel, at least 5/16 of an in. you will have no pump lever action to build pressure. may require building up end of rod.
