Posted by Bill Thompson on July 11, 2012 at 09:30:48 from (204.13.117.179):
Thanks for all the help. My F-20 did not have spark and the wife would not hold the wire to check the spark. It was the condenser. It was shorting out on the top of the cover. Very easy to replace with the Mag. on the tractor. Started right up.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
