Re: 100 mower question
Posted by Mark Robke on July 11, 2012 at 18:06:07 from (75.89.175.82):
In Reply to: 100 mower question posted by Karl in MD on July 11, 2012 at 17:56:32:
I think it should be under the lift cylinder; assuming fast hitch. THere is (I think) a small hole where the chain attatches and a larger hole for down pressure. You do not want down pressure for almost everything.
MARK
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
