Posted by farmallhal on July 11, 2012 at 19:38:33 from (76.4.183.240):
In Reply to: Tractor Serial posted by Maxer on July 11, 2012 at 17:33:40:
If your tractor is a Super C is MUST have 6 s/n digits and noted by CNKS. A few things where the C and SC are different are: 1) the fuel tank sits up above the hydraulic unit by a couple inches on the SC, 2) the brake and clutch pedals have a curve in them on the SC and are not straight like on the C, 3) the brake housings are cast pieces with (5) cap screws attaching them to the tractor on the SC instead of formed sheet metal housings on a C, 6) the grill will have an extra wide bar below the bottom cross bar about 2" wide on the SC where the same bar on a C is about the same width as all the others. Also, look for casting codes which are two numbers separated by something that looks like a flat head screw followed by a single letter - these codes appear on almost every large casting on the tractor. The easiest one to locate is on the upper left hand corner of the transmission cover by the clutch pedal next to a part number ending in R1 or R2 usually. Also, right below the forward most spark plug and behind the governor control rod is the engine serial number stamped onto a flat machined surface following the letters FCM. On my Super C the difference between the chassis s/n and the engine s/n is the engine one is 6300 higher. Hope this all helps and post back what you find and if you could provide a couple photos it would certainly help, Hal.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
