Re: Started H tonite...went crazy (the tractor that is)
Posted by farmallhal on July 11, 2012 at 19:43:27 from (76.4.183.240):
In Reply to: Re: Started H tonite...went crazy (the tractor that is) posted by BruceS. on July 11, 2012 at 19:25:00:
Not really and that is probably your problem unless you also distrubed the throttle or governor control linkages somewhere other then at the carb. You just have to make sure they are properly engaged together as you reassemble back with the carb. A very common problem once the carb has been removed and we have all learned through this same exercise you are doing, good luck, Hal.
