Re: H water jacket cover gasket
Posted by Farmall450lpg on July 11, 2012 at 20:13:36 from (166.147.72.25):
In Reply to: H water jacket cover gasket posted by Zachary Hoyt on July 11, 2012 at 12:54:57:
I have recently found a new gasket maker it is called "the right stuff" it replaces using a traditional gasket that you have to cut or buy. You just spread it out in a nice steady bead and put it on. You can put fluid back in as soon as 1 minute. I have used it on my tractors oil pan, valve cover, water cover, and many more. Have never had a single leak. You can only get this at Napa auto parts and it is around 13 dollars but is sure easier to use and you dont need to use gaskets made out of cork or any other material it replaces it all. Good luck!
