Re: Hydraulic leak farmall h
Posted by pete 23 on July 11, 2012 at 21:08:53 from (74.32.238.2):
In Reply to: Hydraulic leak farmall h posted by TylerFarmallH on July 11, 2012 at 20:51:14:
Frame? Do you mean frame of the hydraulic pump
which would of course be the reservoir. No hydraulic
oil in the FRAME and no gasket between frame on an
H. I think you have a seal leaking or what an H
likes to do once in a while is blow the gasket
between reservoir and the outlet manifold the outer
pressure pipes screw into. Did you take the cover
off below and take a look up at pump.
