Re: Hydraulic leak farmall h
Posted by Dean Olson on July 11, 2012 at 21:12:49 from (98.196.66.64):
In Reply to: Hydraulic leak farmall h posted by TylerFarmallH on July 11, 2012 at 20:51:14:
H's have a belly pump and reservoir.
Refill the reservoir with hydraulic fluid and then remove the cover
plate from under the tractor and see where it's leaking from.
Probably seal at drive.
If so:
Unscrew plumbing from top & sides of the tractor. Those pipes
screw into the reservoir. Remove the cover from under the tractor
and pull the 2 cotter keys and slide the rings back on each end of
the drive assembly. It will now drop out.
4 bolts hold the belly pump assembly in place. Remove them and
the entire, very heavy, pump drops out.
It's now easy to access and replace the seal.
