Re: 284 fluid capacity
Posted by Phil Tibbetts on July 12, 2012 at 03:35:11 from (208.93.14.38):
In Reply to: 284 fluid capacity posted by working dog wv on July 12, 2012 at 02:12:37:
According to my book the transmission takes 50 pints of 80-90 gear oil and the hydraulic takes 24 pints of tractor hydraulic fluid. They are 2 separate units. There should be 2 drains for the tranny and rear differential and 1 for the PTO. They are all connected but have 3 drain points. The drain for the hyd. is on the lower right rear of the 3ph unit. Tranny fill is beside shift lever. Hydraulic is on top right rear of 3ph unit. These are taken from a 364 manual but 384 should be the same.
