removing a block heater on 674D
Posted by Mark in Southern PA on July 12, 2012 at 12:07:37 from (162.27.9.20):
Hi,
I bought a 674D that has a coolant heater located under the belly of the tractor. It's fed from a plug on the left side of the block (just above the starter) and feeds back into the thermostat housing. I'd like to remove the heater. Can I just put a plug in the block and the thermostat housing and eliminate the heater and hoses or do I still have to run a hose from the block to the thermostat housing with no heater in between?
Thank you.
