300U head gasket again
Posted by charlie M on July 12, 2012 at 16:16:12 from (74.34.216.81):
The other day I posted that my 300U was blowing water out the exhaust and pegging the temp gauge. I finally got it apart today. I've never encountered a head gasket problem before so I looking for your thoughts. There was water killing both #1 and #2 cylinders when it was running. I don't see a visible damage to head and block. Gasket had slight damage at #1 and 2 cylinder but not sure if was from removing the head or enough to leak water.Can I still have cracks that I don't see. No sealer was ever put on the gasket when the head was done in the early 90's.Do you think I should just try a new gasket or are there other suggestions.
