Re: carb. settings
Posted by George Steele on October 02, 2000 at 18:26:40 from (205.188.200.27):
In Reply to: carb. settings posted by Mitch on October 02, 2000 at 10:26:08:
Had similiar problem and tried all the things you did and finally found a loose connection on the wire from coil to distributor that was causing engine to die. It just seemed like it was out of fuel but it had a great stream from the tank. I cleaned all electrical connections and it cured the problem. Good luck
Post A Followup
: Re: Re: carb. settings
