I am afraid adding power steering will only make your steering wobble a bit worse. Usually re-packing the wheel bearings, replacing the bushings, bearing & seals in the front bolster, possibly over size bushings if the shaft is really worn, steering wheel shaft u-joints & bushings, replace the bearing in the steering sector.
Once you get all this accomplished you won't beleive how easy it steers, I can turn my 300 from stop to stop with just the spinner knob. Any front equipment like a loader or cultivators and you will want that power steering.
You can use the piority valve ( hard to find a good one used) & behlen drive set up for a 300, 350 or 400, or 450 and use your live hydraulic pump. Your other option would be to use the auxillary mounted power steering pump & behlen drive from the earlier M set up, but with yours already having the live hydraulic pump, I would go that route.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
