Posted by CNKS on July 12, 2012 at 18:15:13 from (216.144.104.128):
In Reply to: Farmall 450 issues posted by IaJosh84 on July 12, 2012 at 17:51:09:
Nothing specific to the tractor. Sounds like you have little flow out of the tank and the carb needs to be cleaned, do that first. The outlet of the tank is probably partially plugged and there is crud in the tank. AND get an Operators manual. If you read that you will discover that the main jet screw needs to be 5 turns out for max power, less for light loads -- and unless it is under load turning it one way or the other does not do much. But if it does not die when turned all the way in the jet is dirty and needs to be cleaned like the rest of the carb. Disassemble and soak the carb in a gallon of real carb cleaner, not the spray on stuff. Plugs, points, wires, timing, etc may also have some part, but I think the main problem is fuel.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
