Re: Injector removal on an Farmall MD
Posted by sflem849 on July 13, 2012 at 05:02:26 from (69.197.84.39):
In Reply to: Injector removal on an Farmall MD posted by rustred on July 12, 2012 at 20:50:10:
Yes you can. I through bolted the injector and pulled it out. I then flipped the puller 90 degrees and used the tapped fine thread holes to pull out the nozzle body retainer. The hole spacing is the same for the injector and the nozzle body retainer so you can use the same puller. Like I said, it takes a lot more slide hammer than the one shown to pull out the nozzle body retainers.
