Re: Super C hydraulic line
Posted by NoNewParts on July 13, 2012 at 06:23:26 from (67.240.145.25):
In Reply to: Super C hydraulic line posted by Charllie in MO on July 12, 2012 at 19:17:59:
like said, since you have a SC, best option
is the factory lines, valve setup from a fast hitch
the bypass block is also a good option
saw one setup on ebay where the pressure line
was cut and sent to a remote valve, then back to the
line to go into the factory setup
on one of my SC's which needed a total rebuild on the
touch control factory hydraulics...
(stuck valves, pump deadheading always, factory remote valve was also junk)
I didn't need them, so I got regular C lines, and made a block off plate
with just the suction line hole drilled out.
removed the plug from the pressure side of the flange.
routed it thru an open center valve, with the valve return plumbed to
the touch control drain.
So, the touch control is just a reservoir.
works fine to run my fast hitch
Today's Featured Article - 12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition. ... [Read Article]
