Re: Super C hydraulic line
Posted by mkirsch on July 13, 2012 at 06:40:18 from (64.80.110.74):
In Reply to: Super C hydraulic line posted by Charllie in MO on July 12, 2012 at 19:17:59:
Either way works, but you can go on ebay and pick up a bypass block for a Super C any day of the week. The fast hitch lines and valve are a little more difficult to come by.
There's no need to cut anything. Besides you need the hydraulic block as a reservoir for the oil.
You also need an OPEN CENTER hydraulic spool valve, mounted in a convenient location near the steering wheel.
Follow the instructions that come with the bypass block for installing and connecting to the tractor and valve. It will tell you which plug to remove and which hose connects to the IN and OUT ports on the valve.
