Posted by gene bender on July 13, 2012 at 07:15:51 from (67.55.226.123):
In Reply to: farmall b anh posted by bruceneva on July 13, 2012 at 06:22:04:
Does your mag have a coil mounted out side or is it still under the cap on top. Best way to check for spark just pull a sparkplug and put the wire back on and make sure the plug is grounded and you can see the spark that way you wont get a shock.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
