Re: Voltage Issues in 450
Posted by Hugh McKinney on July 13, 2012 at 07:20:29 from (99.195.64.176):
In Reply to: Voltage Issues in 450 posted by Joel Wilson on July 13, 2012 at 05:28:42:
Well, believe it or not, I had almost the exact same problem with my 1957 vintage 450, and I was absolutely stumped. What was it? The battery cable snakes its way from the negative post to the tunnel that goes forward (near your feet) through several other twists and turns. It looked like a perfectly okay battery terminal, even when carefully examined. I took it off, and put on a new one, the problem disappered and has never come back. Apparently the insulation in one spot was very thin, and it was able to discharge the battery overnight, against a ground somewhere (but I never found it). Change out that battery cable. Good luck!
