Re: Voltage Issues in 450
Posted by Janicholson on July 13, 2012 at 07:42:27 from (96.24.99.126):
In Reply to: Voltage Issues in 450 posted by Joel Wilson on July 13, 2012 at 05:28:42:
I agree With mkirsch, The ""new regulator may be sticking closed on the cutout points. Those have a delicate adjustment, and often just a bent tab to make the adjustment.
Charge the battery with one terminal disconnected to assure it is getting fully charged. When fully charged:
Use a volt meter to check for voltage between the disconnected terminal and the battery post (with all switches shut off). Less than .15 volts (or nothing) is OK. If it reads 12v or a bit more, there is a direct draw-- like the cutout contacts are stuck closed--.
If you disconnect the Bat terminal from the regulator and keep it isolated, the draw might go to zero. If it does, the odds are it is the contacts.
If between .1 something and 12v, the draw should be traced by disconnecting one wire at a time to isolate the draw. (reconnect each if it does not reduce the draw.
13v Charging might be due to a partially discharged battery. Jim
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
