Posted by old on July 13, 2012 at 11:38:45 from (209.86.226.27):
In Reply to: oil in radiator posted by RalphL on July 13, 2012 at 10:50:58:
Could be one of many problems. If it where me I would drain the oil pan then pull it off and set some card board under it and have the cooling system full. Those engines are wet sleeve so yes it could be a head gasket or a sleeve seal or a crack head or cracked sleeve. Pulling the pan and watch for where the coolant comes from may be able to tell you what is wrong
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
