Re: Super C hydraulic line
Posted by Lmack on July 13, 2012 at 15:11:34 from (24.131.58.167):
In Reply to: Super C hydraulic line posted by Charllie in MO on July 12, 2012 at 19:17:59:
I question pulling a 10' disk with an SC. I doubt it will do more than scrach the top of the ground. The standard disk size for an SC was 5'.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
