Re: Super C hydraulic line
Posted by CNKS on July 13, 2012 at 17:12:44 from (216.144.104.128):
In Reply to: Re: Super C hydraulic line posted by Charllie in MO on July 13, 2012 at 06:29:33:
I pulled a 6 ft heavily weighted tandem disk at full angle 50+ years ago with an H in 3rd gear. Wheel weights and loaded tires. 10 ft behind a SC, even if the HP is close to the H is too big unless all you do is scratch the surface. We used the smaller disk with weight because we wanted to see results.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
