Re: Re: Re: Re: Rear axle gasket
Posted by T_Bone on October 02, 2000 at 22:03:43 from (207.254.53.102):
In Reply to: Re: Re: Re: Rear axle gasket posted by Bergen on October 02, 2000 at 20:18:52:
Hi Bergen, Depending on the gaskets use, I've even used a brown paper bag for gasket material. If the mating surfaces are close to being flat then a thinner gasket can be used. A straight edge will let you know real quick.
T_Bone
Post A Followup
: Re: Re: Re: Re: Re: Rear axle gasket
