Re: Super C Charging Issue
Posted by Janicholson on July 14, 2012 at 10:42:39 from (96.24.99.126):
In Reply to: Super C Charging Issue posted by Reg wilcox on July 14, 2012 at 09:39:04:
With it charged and one terminal disconnected, check the voltage between the post and disconnected terminal. If more than .15 volts, you have some drain. if not, I suspect a bad cell in the battery. Jim
