With the engine running at 1/2 throttle or better use a volt meter and measure the charging voltage across the battery terminals. Should see about 7 volts. If this looks ok check the specific gravity in each cell as been mentioned. Should be around 1.270 and if one cell reads 1.100 replace the battery. I would also replace your battery cables with 00 battery cables using soldered ends. Clean all connections until shiny including where the battery is grounded. Hal
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
