Re: Farmall engine swap
Posted by gene b on October 03, 2000 at 02:33:40 from (63.42.174.49):
In Reply to: Farmall engine swap posted by Marshall on October 02, 2000 at 20:18:42:
it can be done i seen one somewhere i would use the chevy flywheel and clutch maybe an electric fan for the radiator weld the chevy input shaft to the input shaft of the H hot rod tr pullers did it this way there is a B in so dak has a 348 int truck engine looks stock build the exhaust to come out the stock place go for it
Post A Followup
: Re: Re: Farmall engine swap
