Re: Seal Removal Help
Posted by sflem849 on July 14, 2012 at 19:27:09 from (69.197.84.39):
In Reply to: Seal Removal Help posted by freefour on July 14, 2012 at 15:24:11:
I beat the edges in with a cold chisel. I nicked the side on one. :oops: Hopefully that doesn't cause a problem. I didn't have a dull cold chisel so I used what I had.
I then screwed a drywall screw in and pryed them out with that. The first took 30 min and the second took about 5. I learned a lot on the second one! The seals are double leather seals. Only screw the screw into the first seal. Then pry it out. Then screw the screw into the second seal. Then pry it out. Then pound a flat screwdriver around the edges of the big thing that's left that held both the seals. Pry one area in and it will come out pretty easy.
I WIN!!!
third party image
