Re: How does this thing not leak oil?
Posted by Jim Becker on July 15, 2012 at 06:41:18 from (173.74.120.222):
In Reply to: How does this thing not leak oil? posted by SadFarmall on July 14, 2012 at 08:17:27:
Quoting Removed, click Modern View to seeDoes it drain out the bolt hole if you just remove the lowest bolt from the main cover?
