Re: H still needs a tiny bit of choke or dies @ top RPM...
Posted by JT on July 15, 2012 at 11:17:33 from (68.53.181.110):
In Reply to: H still needs a tiny bit of choke or dies @ top RPM... posted by Crazy Red Power in SE-WI on July 11, 2012 at 16:28:10:
When you replaced the manifold and gasket, did make sure all the gasket was off the head? I had the same issue, replaced the gasket, run a die down the studs to make sure threads were clean all the way down, still the same thing, removed manifold again, found some of the old gasket material was corroded to the head, took a small grinder with a scotch bright pad type surface, cleaned ALL the gasket off, down to really shiny steel, was surprised how much gasket was still stuck to head, anyway cleaned down to shiny steel, reassembled and it ran like a swiss watch...problem solved.....
