Re: Carb cleaning
Posted by rustyfarmall on July 15, 2012 at 11:37:32 from (67.55.162.174):
In Reply to: Carb cleaning posted by BigTone on July 15, 2012 at 11:12:22:
BigTone, BEFORE you do anything, remove the fuel line where it attaches at the carb, remove the fuel inlet fitting (requires a 5/8" wrench), and then spray a BUNCH of aerosol carb cleaner directly into that hole. Put it all back together and if that doesn't fix it, get a little more aggressive with the thumping on the front of the carb. If that doesn't cure it, then it is time to open up the carb, OR send it off to a rebuilder.
