Thanks again. I just took off the governor plate and found that the set screw (bolt) on the speed lever very loose. Tightened it up and used a new lockwasher. Restarted tractor but it still speeded up. BTW, The whole gov. assembly seems very "relaxed" (including spring) when throttle is in closed position. Is this the way it's supposed to be? I reread your article on your 51 H and you mention adjusting the "High speed bolt" Which one is this and which way does it turn to lower rpms? Thanks for answering.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
