that is correct, i relized that when you said you had a lockwasher on the speed adjust. the adjustment starts right there at that rod. you need throttle lever wide open then remove the pin next to the rod. then hold the throttle shaft lever and the adjusting block up. if the pin will not go in adjust the block with the rod till it goes in freely. now you are adjusted in w.o. t. now fine tuning is next.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
